hand grips
Old Aug 1, 2004 | 04:37 PM
clinicallyinsane's Avatar
Default hand grips
just bought new grips for my scrambler but the old ones wont come off
any tips on how to get them off without cutting them
thanks
Old Aug 1, 2004 | 04:52 PM
fishslab's Avatar
Default hand grips
I usually use compressed air. If there are not holes in the end, poke a small hole in them. Next take your blow gun attatchment(or something similar) from an air compressor and force air into one end. It should blow the oposite hand grip off. Next cover the bar end with your hand, put the nozzle in the next side and blow. You have to let it slip off while blowing into it. If you don't have a compressore then you can try rolling them off, but it's a major pain.
Old Aug 1, 2004 | 05:02 PM
scrambler123's Avatar
Default hand grips
what works good when you put your new ones on is to spray some clearcoat inside them makes them slip on easily and stick to the bars once it dries.
Old Aug 1, 2004 | 05:08 PM
Sceiks's Avatar
Default hand grips
WD-40 and the little spray tube.
Old Aug 1, 2004 | 08:29 PM
BeltDrive's Avatar
Default hand grips
I cut the old ones off and when it came time to put the new ones on I used some soapy water and it worked lake a charm.
Old Aug 1, 2004 | 11:05 PM
csamayfield55's Avatar
Default hand grips
air ithe best just like fishslab said also when you put the new one on it helps to have a buddy there to hepl you, I shot one of my new grips about 30 feet down the driveway when I went to put them on!!![img]i/expressions/face-icon-small-happy.gif[/img]
Chris
Old Aug 1, 2004 | 11:18 PM
Sceiks's Avatar
Default hand grips
I did that @ the track one day with my little compressor. I was trying to dry my glueing agent when i blew the grip off the other side. BEFORE THE RIDE.
One of my better days[img]i/expressions/face-icon-small-wink.gif[/img]
Hack714
Sep 26, 2015 08:11 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
