Alum rims (fronts) for the Trailblazer 250
Old Aug 3, 2004 | 01:04 AM
AgentOrange51's Avatar
Default Alum rims for the Trailblazer 250
are these available? Trying to lighten up this heavy hog. any other weight saving ideas ???
thanks
Old Aug 3, 2004 | 01:09 AM
tbsleeper's Avatar
Default Alum rims (fronts) for the Trailblazer 250
remove floorboards, different handlebars, and if u dont need it remove teh sprocket guard u will get alil power back
Old Aug 3, 2004 | 01:11 AM
BigBadScrambler's Avatar
Sure are. ITP or Douglas have them. I would suggest going with at least a .190 thick. The front rims are 10" diameter with a 4/156 bolt pattern and 2+3 offset. They are the same bolt pattern as the banshee, so you use those rims too
Old Aug 3, 2004 | 01:12 AM
thanks for that info. On the floorboards, should i just replace them with nerfs or ??
Old Aug 3, 2004 | 01:13 AM
scrambler123's Avatar
remove oil injection, battery, starter, cut off battery box, new front bumper, remove sprocket guard, remove skid plates, new exhaust, remove floorboards, cut off front floorboard mount, shave plastic.
Old Aug 3, 2004 | 01:31 AM
how beneficial would the RCR stage one kit be?
Old Aug 3, 2004 | 01:32 AM
it would be very beneficial improves perfomance significantly and will cut some weight.
Old Aug 3, 2004 | 10:19 AM
tbsleeper's Avatar
bbs do the banshee rears and fronts fit??????????
Old Aug 3, 2004 | 01:16 PM
DGpolaris2346's Avatar
TB i only think the fronts are the same as a banshee.
Old Aug 3, 2004 | 03:07 PM
Just the fronts
