Superwinch ATV3000 cable
Old Aug 5, 2004 | 01:20 AM
tyler711's Avatar
Default Superwinch ATV3000 cable
OK i had a dealer install a winch on my 04.5 SP400, and when i got it i was surprised to see not a warn but a Superwinch 3000lb. Ok the winch can pull a ton of weight, but the cable seems messed up. For example, if you let ANY slack on the cable, the remaining line on the drum all unspools and backlashes, so you must unwind the whole cable and then rewind it, feeding it back and forth by hand. Also, when powering in with a load, even at no line angle, it does not evenly feed back in forth, it just piles up very quickly, eventually hitting the frame outside the drum and damaging the cable. Even though i am very careful, ie. winch in one foot, then unwind, and rewind feeding by hand, there are many crushed and frayed spots on the cable- and this is after one use... do winches usually uncoil when they do not have a LOT of force pulling on the line? any help would be appreciated...
Old Aug 5, 2004 | 11:38 AM
tyler711's Avatar
BUMP
Superwinch wrote back and said that all winches have this problem- but mine is so bad i can only winch in a foot or so, then must rewind the whole cable manually...
Whitelx1
Oct 2, 2015 10:55 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
craacker
Sep 9, 2015 04:32 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
