Rear Hub
Old Aug 9, 2004 | 03:40 PM
bigjohn88's Avatar
Default Rear Hub
The rear hub on my trailblazer has stripped out twice in the last 2 months. What could cause the hubs to strip out this often? I just replaced it around a month and a half ago and it stripped out again today. Any ideas would help.
Old Aug 9, 2004 | 05:21 PM
thewayout420's Avatar
Default Rear Hub
your talking the splines on the hub are stripped,so now its just spinning around the axle?
Old Aug 9, 2004 | 07:58 PM
ftwflh's Avatar
Default Rear Hub
When you replace the hub put some silicon on the splines and tighten the nut good and tight.My 400 Sportsman used to strip hubs all the time until I started doing this.
Old Aug 10, 2004 | 12:54 AM
bigjohn88's Avatar
Default Rear Hub
yeah the splines are stripped so it just spins around the axle
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
