drive belt tension,adjustment????
Old Aug 11, 2004 | 02:50 PM
paulzaho's Avatar
Default drive belt tension,adjustment????
I realized that I have too much play in my drive belt. How do I tighten this up? I've heard lossening the motor mounts and moving the motor forward. I've also heard to add/remove shims. Has anybody had to do this? Any help is always apreciated, I want to ride this weekend and would feel alot better if this was fixed.
Old Aug 11, 2004 | 04:22 PM
paulzaho's Avatar
Someone has to have done this before. Anyone?
Old Aug 11, 2004 | 05:14 PM
thewayout420's Avatar
if belt deflection is out of specification,adjust by removing or adding shims between the driven clutch sheaves.remove shims to decrease deflection,add shims to increase it..
Old Aug 11, 2004 | 08:58 PM
scramblerXrated's Avatar
buy a new belt.
if you have a service manual, it should say just what the belt wear tolerances are.
if you have too much belt play, it prawly just worn out.
X
Old Aug 11, 2004 | 09:12 PM
what makes you think your belt is loose?there should be some play in it..
Old Aug 12, 2004 | 09:32 AM
paulzaho's Avatar
When I take a straightedge across the two clutches, my belt has more than 1 1/8 play in it. This is with the new belt installed. Can I get shims from my polaris dealer?
Old Aug 12, 2004 | 09:42 AM
CED's Avatar
CED
Remember that the belt should ride about an 1/8" on top of the secondary.
Old Aug 12, 2004 | 09:50 AM
Bubba297's Avatar
Also remember that the tension is checked by lightly pushing down on the belt. If you push down fairly strong then you might be over doing it. Like CED told you, the belt should ride above the secondary clutch just a bit.
Firefighter400
Oct 8, 2022 06:38 PM
Cummins Driver
Sep 11, 2019 01:22 PM
toonces
Jul 31, 2015 09:27 AM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
