Someone please help me!!!!
Old Aug 22, 2000 | 12:17 PM
Jerrod695's Avatar
OK heres the deal i have a trailboss 325 that i am going to be selling soon and i hear a really bad grinding noise coming from around the pvt well i guess it is kind of a grinding noise but it just sounds really bad . At first i thought it was my chain guard but i took it off and it didnt help any!! I need to find out what this is and FAST! It is not under warranty anymore. Someone help me!
Old Aug 22, 2000 | 01:17 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Change your tranny fluid and see if there are any metal shavings/chunks in the oil.
Old Aug 22, 2000 | 09:54 PM
Jerrod695's Avatar
Anyone else??? I really need to know what the problem is!! All replies are appreciated.
Old Aug 22, 2000 | 10:17 PM
ScramblerDrew's Avatar
Here are 2 places to look, 1 sometimes rocks can get pinched between the rear sprocket and the guard, this will cause a bad noise. 2 Rocks and dirt can get into the small space in front of the front sprocket, once they get up there they bounce around on the sprocket and eventually get ground down enough to fall out. This will make the noise you are hearing.
Hope this helps.
Lastly you might want to check the condition of your chain when the rollers start getting loose they will make a grinding noise under load.
See Ya Drew
Old Aug 23, 2000 | 09:59 AM
DaBoss's Avatar
I had a similiar problem with my TB. I always heard a noise from the back that sounded like the chain rubbing on the chain guard. I adjusted that chain guard a couple of dozen times... Last ride my friend noticed that when the chain goes around the rear sprocket it wanted to keep following it because the links were binding. When it got past the sprocket it would snap up from then tension. I could grease it but it wouldn't last more than 5 miles. It was only a few links around the master link.
I am getting a new chain put on right now... under warranty.
Old Aug 23, 2000 | 09:13 PM
Jerrod695's Avatar
ok thanks for the replies. I dont have any expirience with chains so where can i get a good one that will last on my boss and how much will they run and what size is it?
Jerrod
