z 400
Old Sep 5, 2004 | 08:55 PM
chazekxt's Avatar
Default z 400
yes 3500.00 to 3600.00 is better
Old Sep 5, 2004 | 09:03 PM
RAJ's Avatar
RAJ
Default z 400
I have aguy we ride with 03 Z was cheap made. The frame is junk. They did alot of changes in 04.
Old Sep 5, 2004 | 09:04 PM
scrambler123's Avatar
Default z 400
RAJ 03 Z's were not junk. they changed very little from 03 to 04. I ride with many 03 Z-400's and none of them have ever had a major problem.
Old Sep 5, 2004 | 09:13 PM
RAJ's Avatar
RAJ
Default z 400
Well his is JUNK! He jumped it one time and bent the frame. I have heard alot of bad stuff on the 03. They did make the frame stronger on the 04. I know this for a fact. We talked to alot of guys at Hatfield & McCoys that had the Z.
Old Sep 5, 2004 | 09:23 PM
  #15
BeltDrive's Avatar
Default z 400
I think suzuki replaced some 03 frames, upgraded the following year.
New 04 Pred 4695.00
Old Sep 5, 2004 | 09:39 PM
  #16
chazekxt's Avatar
Default z 400
the first of the 03 were weak. but they fixed that by early 04
Old Sep 5, 2004 | 09:45 PM
  #17
RAJ's Avatar
RAJ
Default z 400
Thats what I thought.
Old Sep 5, 2004 | 09:46 PM
  #18
Default z 400
we have an early 03 that has been ridden very hard with 0 problems.
Old Sep 6, 2004 | 01:32 AM
  #19
EAB's Avatar
EAB
Default z 400
A buddy of mine has an 03 and an 04. He switched some upgraded parts from the 03 to the 04 and we couldnt believe what a pain it is to work on. Pull the tank to get at the plug? Pull the battery and rear harness to remove the rear plastic? Make sure you get your jetting right the first time cause you wont want to pull that carb again.
Old Sep 6, 2004 | 03:24 AM
  #20
yammaslamma's Avatar
Default z 400
it looks like i am going to get one..they seem to have decent reviews and i have found a friend that wants my quad for 3000, so i will let you all know after i get it takin care of.
