hot seat jetting
#21
Repairman ,
Did you get it to quit popping on decelleration ?
Rick
PS --> Thanks guys , I'm just trying to help . Most 4 strokes will pop on decelleration if the pilot circuit is too lean . If you can't turn the screw out enough to fix it , go to the next sized larger pilot and try again .
Rick
#22
thanks guys for the info, i will try tonight after work. i havent even touched the fueul/air screw yet. i have to drill out that stupid plug. no big deal. this website and forums rock. keep up the good work. thanks
#23
An easy way to get that plug out is to drill a small hole and insert a long self taping screw in it. Then you can grab ahold of it with pliers and yank it out
#24
dont listen to me? you guys said that was normal and to leave it!!!
atleast i was headed in the right direction... depending on the pop a MJ change could be needed... or for fine adjustments the fuel screw can be used...
right rick!?!?!?!?!?
#25
#26
wow BBS.....hozed needs hozed down......a little fiesty on that side of the keyboard.....good thing you don't still live with him in da nile, and speaking of the, you are about due for a relocation aren't ya??
#27
#29
are you guys saying you want to rip my pants off me?
****... ill let ya... [img]i/expressions/face-icon-small-wink.gif[/img]
