the beast is down
Old Oct 3, 2004 | 05:12 PM
Doyle's Avatar
Default the beast is down
i got a 1996 scrambler it wont start that eletric start is shot but i used the pull start and it worked and now it wont work at all its being dumb i was ridein it the day before help please!!! and also right by the transmission then its makeing a vibrateing sound i dont know like again help!!! doyle
Old Oct 3, 2004 | 05:42 PM
tbsleeper's Avatar
wats the vibrating sound soudn like? im havin a terrible vibratin noise at idle!!! its terrible!!!
Old Oct 3, 2004 | 05:48 PM
TheWeedman's Avatar
i think all trailblazers rattle like crazy, i know my aunts rattles so bad the tires shake!
Old Oct 3, 2004 | 06:06 PM
tbsleeper's Avatar
not htat kinda rattle like a real loud buzzing noise
it wont shake wen tuned properly atleast mine dont shake much at all anymore
Old Oct 3, 2004 | 06:46 PM
Hozed's Avatar
i think if you were a little bit more specific you might get some better responces...
Old Oct 3, 2004 | 07:06 PM
Doyle's Avatar
well the quad wont start its dead *** can be but it turns over........ and the vibrateing sound is right by the transmission the plastic and when i pick the plastic up or put force in it it stops im confused please help!!!!!!!!!!!!!!
Old Oct 3, 2004 | 07:20 PM
Polaris500HO4x4's Avatar
somethings loose. try tightning the belt cover
Old Oct 3, 2004 | 07:29 PM
Doyle's Avatar
i did
Old Oct 3, 2004 | 08:10 PM
Crawdad's Avatar
Well, you're saying it's dead and won't start but then you say it's making a vibrating, buzzing sound.
When is this buzzing sound, when you're trying to pull start it? If you want help you need to diagnose it a little better and describe what you're doing when it makes the buzzing noise. If moving the plastic stops the buzzing I would say remove the plastic and see what it is you're touching when you push in on the plastic.
Old Oct 3, 2004 | 10:34 PM
tbsleeper's Avatar
my buzzing noise seems to come from the carberator or somewhe5re aroudn the engine..can someone help me wit that??
