Changing the axel
Old Aug 28, 2000 | 07:17 PM
gixxer600's Avatar
How do I take off the hubs on the back axel. In other words step 1) take off tire and wheel
But then does the hub with the four bolts just pop off after you remove the center bolt or do i have to have some special tool to pry it off. Like a pulley puller from an auto store.
Old Aug 29, 2000 | 12:23 AM
mudmachine's Avatar
Just take the axle nut and cotter pin off, and the hub will slide right off in your hand. Make sure you put some anti-seize on the splines before you re-install it. Also, run it for awhile, then re-tighten the nuts.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
