3 Wheels pulling???
Old Oct 9, 2004 | 07:13 PM
tprice's Avatar
Default 3 Wheels pulling???
I have a 97 425 mag that I use for hunting. Yesterday while going through a swampy area to retrieve a deer I bogged down in the muck while going up a small incline. I noticed that my left front wheel was not turning. I had the atv in 4 wheel drive and the right front was loosing traction, had to use my winch to get.
I have never noticed this before. I have replaced all chains last year and even though it has some age on it the atv is well taken care of. What should I check first or is this normal, I seem to always remember all 4 wheels turning. I thought I had noticed this a few weeks back but did not think any thing else about it.
I do not hear any noises, popping or else when this happens. I did a couple of years ago break the front sprocket and damage the right front when the chain came off and got in a bind but that was fixed by my local dealer.
Thanks for any help
Old Oct 9, 2004 | 10:21 PM
Krank's Avatar
You prolly have a broken wire going down to that wheel. Fairly common.
Old Oct 10, 2004 | 04:17 AM
weez440's Avatar
it always will be common trust me once you learn how to fix it then there will be ease later on get familiar with your machine and it will go a long ways in keeping the upkeep
Old Oct 10, 2004 | 08:23 AM
tprice's Avatar
THANKS, That makes since I will check that out today.
Old Oct 10, 2004 | 12:24 PM
tprice's Avatar
Thanks Krank, I went out and looked at the left front and the first thing I saw was a broken wire.
THanks for the help!!!!!!!!!
Old Oct 10, 2004 | 05:08 PM
4wheelerfred's Avatar
i am gunna tell my friend cuz he is having the same problem.
Old Oct 10, 2004 | 07:37 PM
wannaracelt500's Avatar
i ridden a yamaha bigbear 400 2003 and an suzuki vinson 500 2001 and both quads quads only spun three tires do they come like that or are they bad
Old Oct 10, 2004 | 08:06 PM
Krank's Avatar
Your quads are built like that. Polaris's are built to turn all 4 wheels when the 4X4 is engaged. Yours are working fine.
Old Oct 10, 2004 | 08:17 PM
that somthing was wrong wit them ok thanks (i have 2 2x3 isint that something
Old Oct 10, 2004 | 11:28 PM
7QuadSport7's Avatar
they are called 4 weel drive differential not lock only 3 weels turn what you do is play with your front brake handle wile iits turning it switches torch from the left wheel to the right trust me i work for polaris
