NOISE
Old Oct 15, 2004 | 01:07 PM
HELLHOUND's Avatar
Default NOISE
I have a 04.5 sportsman 500 it runs good but there is a noise that is hard to describe at idle in any gear h,l,n,p,r it sounds kinda like a chain noise or a metalic whiring noise like i said its hard to describe under power it seems to dissapear any ideas.
thanks
Old Oct 15, 2004 | 04:57 PM
Charlie's Avatar
Default NOISE
It could the front driveshafts where they come out of the gearbox. At higher speeds they are rather loud and more pronounced when decelerating. Grab hold of the u joint and pull up and down, you will find quite a bit of movement. The 05 model have CVs inside and out which seems to reduce the noise.
Just another noise for people to wonder about.
Old Oct 15, 2004 | 07:30 PM
moosehunter's Avatar
Default NOISE
Hey Hellhound....
I see your ride is a 04.5. How many miles have you put on it? I believe I know the sound you're talking about. Mine did the EXACT same thing for a while. My dealer told me it's due to the tight assembly tolerances and the noise would go away after a while.
Hope this helps....
Old Oct 15, 2004 | 09:23 PM
yaK's Avatar
yaK
Default NOISE
its just the way they sound....I used to hear mine do that but now i think im used to it!
Old Oct 15, 2004 | 09:54 PM
HELLHOUND's Avatar
Default NOISE
I have about 40 miles on it
Old Oct 15, 2004 | 10:10 PM
HELLHOUND's Avatar
Default NOISE
Also this noise is only ay idle not moving
Old Oct 15, 2004 | 10:37 PM
401's Avatar
401
Default NOISE
Sounds like it is idled too low.That's the auto decompresion release you are hearing.Kinda sounds like a timing chain slapping.This is normal.Just idle it up a bit.If you get it too high it will be hard to shift into gear and also creep.
Old Oct 15, 2004 | 10:53 PM
Default NOISE
Yeah, that's sort of what I thought... Your machine is still a baby!! [img]i/expressions/face-icon-small-smile.gif[/img] After a while that whiring sound will die down... And that chain noise is just what 401 said. It's the compression release. Turn up your idle a bit....
Old Oct 16, 2004 | 12:10 AM
HELLHOUND's Avatar
Default NOISE
Thanks ill try to raise the idle a bit. About what should the tach read
Old Oct 16, 2004 | 07:32 PM
NBsportsman's Avatar
Default NOISE
Should be 1200RPM.....
