Drag Race!!!!
Old Nov 29, 2004 | 12:24 AM
UBETRUN's Avatar
Default Drag Race!!!!
It's not that hard to make struts, Home Depot and Lowes sell square aluminum tubing. Buy the size that's closest to your shock mounts, remove the shocks while the quad is lifted by the frame, adjust the ride height on the jack to where you want it, measure the shock lengths from eye to eye, cut and drill the aluminum tube, and bolt up your new struts. Much cleaner than trying to strap down the shocks and the struts weigh less. Plus, it's only a few bolts to change out the struts when you want a functional suspension again.
Old Nov 29, 2004 | 12:39 AM
RAJ's Avatar
RAJ
I did this already....they work great, we was in a hurry....and I did not have time to take the shocks off, we was running behind. I took a pic of it with the home made struts on it, they are in my gallery. Thanks for the imfo. though.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 29, 2004 | 09:58 AM
scramblered's Avatar
what is the engine peak hp at (rpm)?
at rev limiter your motor doesn't have the same hit than at peak rpm,,,
you should choose a ratio of gears that put the engine right out in the meat in what gear you're launching...
Old Nov 29, 2004 | 01:06 PM
CincyScrambler's Avatar
I have been drag racing for 12 years now and have not once took off in first gear. It just depends alot on the track and tires you are running, , if im running 4 snows i can take off in third and run that all the way..... 150ft tho.... BTW where did you race at? if i would have known about it i would have brought my little LT 250 and let you scratch your head on why you cant beat a bike half the size.
Old Nov 29, 2004 | 01:26 PM
  #15
RAJ's Avatar
RAJ
We race at Happy Hollow in Peebles, every other weekend.
Old Nov 29, 2004 | 01:47 PM
  #16
omahapredator's Avatar
i'll take a piece of that LT250!!!!
Old Nov 29, 2004 | 01:50 PM
  #17
RAJ's Avatar
RAJ
LOL....hey Omahapredator......did ya get my pm?
Old Nov 29, 2004 | 02:11 PM
  #18
it wont let me reply to it????
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 1, 2015 01:45 AM
