Sp500 HO Sagging Front end
Old Dec 1, 2004 | 08:38 AM
Tmcb's Avatar
Default Sp500 HO Sagging Front end
Anybody got the part # for the 700 Spring and the rating. Thanks
Old Dec 1, 2004 | 08:18 PM
junkie's Avatar
They cost me $60 for both springs. I can not remember the part #, but a polaris dealer should know. Just tell them you want to upgrade to the 700 springs. It is fairly easy to install them. I have never messed with suspensions or really any other mechanics(besides the usual spark plug and oil change) and I changed them in about two hours for both(alone). I am sure if you had someone helping it would take less time. Good luck w/ everything.
junkie
Old Dec 1, 2004 | 08:30 PM
jwyles's Avatar
Check on the Polaris website. You can download parts manuals for ATV's.
Old Dec 3, 2004 | 07:46 AM
Tmcb's Avatar
Thanks for all the tips guys. For now I'm going the cheap route. I found some meterial to use as a spacer and bought a set of coil spacers from the pure polaris site. Got 20% off for answering a survey.
Old Dec 6, 2004 | 09:43 AM
  #15
Tmcb's Avatar
Put 1" spacers in this weekend and it made a big difference. Forgot to take before and after pics but it was well worth it. Spent about 1 1/2 hrs not to bad considering I did the one side twice put the one piece in backwards. I think I have a bad strut the left one seemed pretty soft and not much resistance. Anybody know what one should feel like?
Old Dec 6, 2004 | 01:13 PM
  #16
jwyles's Avatar
I see you have the 56" glacier plow system, Which blade is that? Is it the one way?
Old Dec 6, 2004 | 01:14 PM
  #17
jwyles's Avatar
I am debating between the polaris one way and the Moose 60" county plow. Seems its really high (26") which is what I want. I am uncertain of the height of the polaris blade.
Old Dec 6, 2004 | 01:50 PM
  #18
Tmcb's Avatar
Jwyles
Yes it is the one way blade. I can get some measurments from it tonight. Even take a few pics if that would help.
Old Dec 6, 2004 | 08:45 PM
  #19
jwyles's Avatar
Ok, kewl. That would be great! I would rather buy polaris so it would bolt right up. The 20% discount for the survey also helps!
Old Dec 7, 2004 | 06:42 PM
  #20
jwyles's Avatar
Originally posted by: Tmcb
Jwyles
Anything on those specs yet?
