porting??
Old Dec 5, 2004 | 10:59 AM
Jayblazer's Avatar
Default porting??
does the jug get ported or is it the head or is it both???
Old Dec 5, 2004 | 11:07 AM
thewayout420's Avatar
Default porting??
the cylinder gets ported,and the head gets shaved down..
Old Dec 5, 2004 | 11:11 AM
omahapredator's Avatar
Default porting??
i thought the heap gets ported and polished and the cylinder gets honed...unless you bore it then you either sleeve or plate it then oyu hone it!
Jayblazer's Avatar
Default porting??
does the head have to be shaved??
Old Dec 5, 2004 | 11:17 AM
Default porting??
maybe im wrong but that was my understandment of it,i dont think you have to do any head work but thats where the higher compression comes from so its well worth it,i think anyway..
Old Dec 5, 2004 | 11:24 AM
Troyer23J's Avatar
Default porting??
You would port the head. The head can get milled down to raise compression, doesnt have to be. Boring the cylinder should be done if it has any damage in there, you bore it out to the next piston size up. Doesn't have to be re-sleeved.
Old Dec 5, 2004 | 11:26 AM
Default porting??
ok,so i guess i was wrong..sorry
Old Dec 5, 2004 | 11:43 AM
Troyer23J's Avatar
Default porting??
NO NO NO, I typed it wrong.
You would port the cylinder. The rest is right though.
Old Dec 5, 2004 | 11:44 AM
Troyer23J's Avatar
Default porting??
My bad. Sorry.
Old Dec 5, 2004 | 12:47 PM
tbsleeper's Avatar
Default porting??
on a 2stroke the cylinder is ported..on a 4stroke the head is ported
