tach help?
Old Dec 17, 2004 | 11:25 PM
braveops's Avatar
Default tach help?
i just put a sun tach in and and it does nothing til i rev the **** out of it then it flys up then drops to 0 at idle? i set it on 4,6,8 same thing what gives?
Old Dec 18, 2004 | 12:31 AM
MikeMurray's Avatar
Default tach help?
It won't work it's made for a auto/car motor
take a look at the TMI@tmiled.com
It works great will go up to 30,000RPM
Mike
Old Dec 18, 2004 | 12:39 AM
mudmaster250's Avatar
Default tach help?
Mike
thats deff not true. my sunpro worked fine untill my battery went out and it fried the thing. now it just goes in circles, but before my battery went bad it worked great.
Old Dec 18, 2004 | 02:25 PM
braveops's Avatar
Default tach help?
i dont know why i hooked it up like u said in the last tach posting mudmaster?
Old Dec 20, 2004 | 09:01 AM
braveops's Avatar
Default tach help?
well i picked up another tach off a 02 sled damm this one is big almost 5'' i will try it a see how it works it is a 6 pulse so i hope it is fine
Old Dec 20, 2004 | 10:11 AM
Bubba297's Avatar
Default tach help?
Are you trying to hook one up one your 500, or 400?
Old Dec 20, 2004 | 11:56 AM
braveops's Avatar
Default tach help?
SORRY BOUT THAT ON THE 400 THANX
Old Dec 20, 2004 | 12:05 PM
Bubba297's Avatar
Default tach help?
A 6-pulse is designed for the 4-strokes if I'm not mistaken. A regular sunpro should work fine in the 4 cylinder setting. Black to ground, red to ignition on, white to lights on, and hook the green to the yellow/red stripe wire coming out of the stator.
Old Dec 20, 2004 | 02:46 PM
braveops's Avatar
Default tach help?
bubba this tach came off a 2 stroke sled ? are the 400`s 6 pulse per rev? if not what are they?
Old Dec 20, 2004 | 05:59 PM
Default tach help?
if u used teh same post i used and did it right i cant see why its not workin. makes no sense to me.
