2005 Sportsman 800 Sputters
Old Dec 21, 2004 | 02:43 AM
  #21
BornDirty's Avatar
Default 2005 Sportsman 800 Sputters
I am not sure if the heet helped or not I will ride the hell out of it this week and see what happens, after all of the gas has been run through Maybe it will clear. the gas did not have any water bubbles yet it looked less colored than I expected maybe the heet mixed all in so I could not see it. if I run all the gas out refill than I will know.
Old Dec 21, 2004 | 03:41 AM
  #22
Snowwolfe's Avatar
Water can not mix with gas. You can see it in the bottom of a container full of fuel. The alcohol in the heet mixes with the water then this mixture can be mixed and burned in the gas. Good luck getting it fixed whatever it is.
Old Dec 21, 2004 | 10:08 AM
  #23
Dragorus's Avatar
be sure to check the p. brake switches.
Old Dec 21, 2004 | 01:50 PM
  #24
BornDirty's Avatar
I agree that is why yo use heet that can mix with water and then the mixture can mix with gas that may be why the gas looked a little lighter without that blueish color.
Old Dec 21, 2004 | 10:10 PM
  #25
500DUSE's Avatar
You guys arent running K&N filters by any chance are ya???
Old Dec 21, 2004 | 10:16 PM
  #26
adgr71's Avatar
the service guy told me that if my 800 started to run bad or miss to tap on some sensors under the seat beside the air box and that should fix it . you could try that???
Old Dec 21, 2004 | 10:22 PM
  #27
Dragorus's Avatar
You shouldn't have to do that at all....if they tell you to do that then they know something about a possible defect and don't want to actually tell you......Keep up with the polaris recalls....I'm sure there is due to be one for this!!!!
Old Dec 21, 2004 | 10:54 PM
  #28
BobKat's Avatar
I had a similar problem on my 05 700 EFI, both spark plug boots where very loose and one would not stay on.
It would idle fine but on rough terrain or high revs it would miss. Dealer replaced wires, runs great now.
Old Dec 21, 2004 | 10:59 PM
  #29
Snowwolfe's Avatar
If you run into this problem again it is very easy to slightly crimp a boot with a pair of pliers to make it tighter.
Old Dec 21, 2004 | 11:15 PM
  #30
Dragorus's Avatar
I agree..
