165 psi comp on 400
Just put a trail mod head on my 4x4. My compression went from 125 to 165. The rest of the engine is stock except for a hpd trail pipe and boysen reeds.
I took it down the road today to see how it acts.. I think I got some detonation going on here. It sounds real "tinny- pingy" And it also runs real eratic at 1/2 throttle. Is this what detonation acts like?
I think there was some low test gas left in my tank. Im gonna fil it up with super next time out. I hope it helps.
How much comp can you get before race gas is needed? What is 165 considered, 12:1?
Thanks for any input.
You need race gas or a mixture ofrace gas and high test fuel to run that compression. 150psi is max on high test pump gas. You will burn a hole in the piston if you keep running it. who's head did you put on?
AZ BAD BOYZ (Dennis)
The head is from Rick Ritter. I talked to him today and he said that my guage may be off.
Im going to borrow another guage and test it again. Im going to mix up a fresh tank of super this weekend, and see how it acts then.
If that dosent work hes gonna send me another.
I tell ya what.. the sound this motor had, was making the hair stand up on my neck.
Welp fellas.. It was the guage. I borrowed another guage from a friend, and I got a reading of 149 psi.
Gonna mix up some super this weekend and giver he11!
Thanks for the help.[img]i/expressions/face-icon-small-smile.gif[/img]
ERICsRAPTOR
Mar 10, 2001 02:38 PM
