plow on my explorer?
I jacked the front end up to spread the springs out and you take dishwashing soap and line the spacer with it (NS, it's in the instructions from Polaris) and then put the spacer in the middle of the spring with the springs in the groove of the spacer and then twist it to where you want it. The dishwashing soap acts as a lubricant. I put one on top and one on the bottom of the spring on both sides. Start to finish, including taking the tires off, probably took 15 minutes.
kampswas
Sep 23, 2015 05:05 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
