34mm carb jetting on a 250
Old Jan 23, 2005 | 01:09 AM
ftwflh's Avatar
Default 34mm carb jetting on a 250
Good deal on the carb. When you guys go to Badlands do you stay or go home?We ussually get a room at the Attica Inn.Close to the Pizza Hut and they got cute desk girls
[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 23, 2005 | 01:29 AM
DGpolaris2346's Avatar
Yea those desk girls are cute. I was thinking about metting all you guys up there in the spring to just let me know a date and ill try to make it.
Old Jan 23, 2005 | 11:35 PM
mudmaster250's Avatar
we usually jsut go for the day but since im gonna be driving with some other ppl we might stay the night and ride two days. i hope
Old Jan 24, 2005 | 01:15 AM
2manytoys's Avatar
Scott,
I found the carb but I still need to look for a couple parts for it. I will PM you with the address when I get everything together. I want to make sure I have everything to make it work. Give me another day or two.
Kurt
Old Jan 24, 2005 | 02:00 AM
  #15
cool, thanks kurt
Old Jan 24, 2005 | 02:36 AM
  #16
jeffro206's Avatar
we built a 2000 tb a couple of years ago. used the 34mm mik carb also. your starting point sounds pretty close. i ran an FMF fatty pipe, AAEN roller clutch, .040 wiseco, full port, and cut head. depending on your riding area, style, etc. a light weight in the front clutch may help too. you have the same gearing i ran. another thing to try is the UFO from HOTSEAT. it mounts into the slide on the carb and helps direct air flow. this will help with throttle response and mid range. i work for as a tech for a polaris dealership and have had very good luck with the ufo's. i mostly put them in the 400's. also, on the tb i used an O8 needle jet, but again all bikes are different so its mostly trying to see what works best for your combo. PS helps to keep notes of all mods, gives you something to go back to. and also, on the polaris always tune the motor in first and then clutch work!!
Cole Hadden
Jun 15, 2025 09:05 AM
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Jul 29, 2015 09:41 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
