Air Pressures
I've tried a few different pressures for my Scrambler. What is the best for a dirt track I have. I'm looking for the best grip I can. Should I run less ro more than the tires say? They are stock OEM, BTW.
Thanks
Thanks
I am not sure what the best psi is technically. But for me, I have found about 5 psi works best. The tire tends to roll over while turning less often at this pressure. The bike also slide corners better at this pressure.
