Scrambler headlight relocation
Old Jan 30, 2005 | 11:22 PM
mudmaster250's Avatar
Default Scrambler headlight relocation
i have custom light mounts, check um out
Old Feb 3, 2005 | 12:42 PM
IdahoSpud's Avatar
Mudmaster,
I have to respectively disagree.
I see you have a 12" sprocket on yours. It hasn't hurt mine or any of the guys I ride with.
when your in 4 wheel drive your on soft ground and spinning tires aways so there is already slipping going on. I don't recomend riding any wheeler on pavement in 4 wheel drive. tough on tires and gears. when I went to new wheels and tires, the back is suppose to be 1 " smaller than the front, but as you can see the back are physically bigger than the front so the smaller sprocket helps get the ratio back to normal.
Tire Size:26x9x12 Front / 25x12.5x12 Rear
Wheel Type / Finish:Type 4 C-Series / Machine
Ride like you just got caught climbing out a window.
exmotocrosser
Sep 13, 2019 06:12 AM
Whitelx1
Oct 2, 2015 10:55 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
