No LCD or AWD
Have a friend coming over to try to find a problem with his 2004 SM700. The problems that are happening in stated as above. Has anybody had any simular problems? Is there a grond wire or something that ties them both together? Thanks for the input.
Thanks for all the comments...Haha. Just a quick update.. As for the AWD not engaging there was a big branch stuck in between the frame and the drive shaft. No LCD I found a red/white wire that was broke under the light pod that went to the ignition. Broke right at the part of the wire that was not in the harness. When I called my dealer to inquire any common problems he stated that the wire ties are very tight for the handelbar wires to loosen those up. Has seen a lot of wires pinched on them. Just a little info for you all.
