New Race Mod Complete :)
Old Feb 14, 2005 | 01:06 PM
Bubba297's Avatar
Default New Race Mod Complete :)
Glad it's up and running again. Time to take out a few thumpers with the auto
Old Feb 14, 2005 | 01:17 PM
POLARISFREAK's Avatar
Gap the plug at .022 and that may take care of the problem. Even though you don't have the higher compression I think that will hep, the stock ignition is pretty weak!
Old Feb 14, 2005 | 01:21 PM
cornfarmer's Avatar
Congrats on the race mod Shawn. I got the trail pipe on and the carb set this morning. I'm quite pleased with the results so far. I'll probably have to do a bit more tweeking on the thing but so far it's a huge difference. Thanks for your help Shawn.
Talk to ya later -Joe
Old Feb 14, 2005 | 05:05 PM
duneaholic's Avatar
Already did.[img]i/expressions/face-icon-small-happy.gif[/img] And they said what is that thing.[img]i/expressions/face-icon-small-shocked.gif[/img]
I'm glad you got it going Joe. Just a pipe makes a big difference. But I have a feeling you won't be satisfied for long.[img]i/expressions/face-icon-small-wink.gif[/img]
I'll try the gap at .022. Is this the correct plug I should use? And did you use the stock ignition when you got your first race mod?
Old Feb 14, 2005 | 11:23 PM
  #15
Whitedog's Avatar
Sweeeeet! What dome are you running?
Old Feb 15, 2005 | 12:50 AM
  #16
modquad's Avatar
Isn't power a beautiful thing. [img]i/expressions/face-icon-small-smile.gif[/img] You'll have this funny "perma-grin" every mornin'. Beware, it gets worse after you ride.
Old Feb 15, 2005 | 01:17 AM
  #17
RickRitter's Avatar
The head is a Hotseat 12 to 1 that I had to work on a bit due to shipping damage .
The girdle used is from Aaen performance .
The case saver is from HpD .
The exhaust is a in frame drag pipe from CPI .
The cylinder was broken off at the base , we welded and reinforced it like we do on the polaris 400 . I have repaired MANY of these broken cylinders , I have yet to see one break after we fix it , if anyone has I would sure like to see it so I can improve my method of repair .
Shawn has a very good example of a well tuned pump gas 400 Polaris . If jetted correctly and *listened to* it will run a long time til it needs a set of rings .
Rick
Old Feb 15, 2005 | 01:26 AM
  #18
mudmaster250's Avatar
is it ok to just re ring things once a year to make it last longer or is that bad for it?
Old Feb 15, 2005 | 02:31 AM
  #19
duneaholic's Avatar
Rick
Thanks for helping out Rick.
Old Feb 15, 2005 | 06:46 PM
  #20
scrambler123's Avatar
I have a 190 in mine which seems big compared to every one else but maybe its because of the trail pipe?
