Carburetor rubbing
Old Sep 20, 2000 | 12:04 AM
Crawdad's Avatar
I was doing some cleaning on my '98 Scrambler 400 tonite and took the air filter & box out. I started it up and let it run and I noticed drops of gas spraying out around the carb. Upon closer inspection I saw it was coming from the bottom of the float bowl. I took the whole carb out to check it and found that the bottom of the carb must have been rubbing the engine because I had a hole worn in the middle of the float bowl drain screw. There's actually a rubber piece under the carb on top of the engine but it apparently didn't protect the entire bottom of the carb. There isn't a whole lot of leeway when installing the carb. It basically just goes in one way. Has anyone else had this problem and what did you do to fix it?
Old Sep 20, 2000 | 08:08 AM
x_scrambler3's Avatar
Have had the same problem an we just got some epoxy an put that on it to fix the whole an built it up a bit.
Ask the Editor
Sep 14, 2015 08:57 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
WesTech
11
Aug 11, 2015 07:55 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
