Barometric pressure sensor on 700efi
Old Feb 19, 2005 | 01:02 PM
jefffoxsr's Avatar
Default Barometric pressure sensor on 700efi
Where is it located? I can't find it in the parts manual.
Old Feb 19, 2005 | 01:10 PM
SPORTSMAN70003's Avatar
HEY YOU ONLY LIKE 1 POST BEING TO 1000 CONGRAGULATIONS.
Old Feb 19, 2005 | 04:56 PM
elkbow's Avatar
I would imagine it is built right in to the EFI control box...
Old Feb 20, 2005 | 12:17 AM
TEXMud's Avatar
In the manual for the 800, its on the page labeled "AIR BOX". Its number 30, and just called sensor. Bascially its on the air intake tube past the air filter.
Old Feb 20, 2005 | 02:27 AM
elkbow's Avatar
Thats the same as on the 700, its called the T-Map Sensor....
Old Feb 20, 2005 | 10:19 AM
jefffoxsr's Avatar
TexMud,
I always enjoy reading your posts. You are a very knowledgeable and helpful person.
When I looked at # 30 in the manual I was thinking that it was the "air temperature" sensor. If it's not, then do you guys know where the air temp sensor is? My understanding is that there is an intake air sensor in the air box and a barometric pressure sensor somewhere.
The intake air sensor is so that the ECM can adjust the a/f ratio for ambient temperature changes, and the barometric pressure sensor is for the ECM to adjust the a/f ratio for altitude changes. Is this correct?
Just trying to figure this out.
Thanks for your help on this.
Old Feb 20, 2005 | 10:39 AM
elkbow's Avatar
Originally posted by: jefffoxsr
TexMud,
that sounds right Jeff, I think the T-map sensor is for temperature, but not really sure if thats how the EFI controls for temperature or if it mainly controls for pressure altitude....don't see a reason why the pressure sensor would be on the intake, I'll have to look through the parts dwgs again.....would be nice to have a design manual.....
Old Feb 20, 2005 | 11:04 AM
jefffoxsr's Avatar
Dave,
I studied the parts manual for a while yesterday and couldn't figure it out. If you could look at the electrical diagram in the back of your service manual I think we can figure this out. It should show all the sensors. We can figure out where they are from that diagram too.
Old Feb 20, 2005 | 11:26 AM
elkbow's Avatar
Jeff....I looked at the schematic.....there is the T-map sensor located on the air intake and a temp sensor, but for engine temperature located on the cyclinder.....don't see any other sensors other than the TPS....
Old Feb 20, 2005 | 11:54 AM
jefffoxsr's Avatar
Thanks for looking Dave. The engine temp would be the coolant. I wonder if it's possible that the one sensor located in the intake measures both intake air temperature and barometric pressure.
