Wheelies
Old Sep 20, 2000 | 11:49 PM
nauvooguy's Avatar
I was wondering anyone here knows how to pop a wheelie with an automatic.
Old Sep 21, 2000 | 12:14 AM
Lurch77's Avatar
What automatic do you have? There are different techniques for different machines.
Old Sep 21, 2000 | 02:34 AM
BONER's Avatar
If you have a stock sp500 you have to Hold the brake, hit the gas hard then let of right when you FEEL the belt engage in low range. I have done this and only been able to lift the fronts slightly cause I have only done it a few times. But the guy who showed me how to do it could RIDE whe wheelie out ont he sp 500. I also did this on a Scrambler 400 with a clutch kit, almost fliped it.
Old Sep 21, 2000 | 04:16 AM
AKScrambler's Avatar
On my Scrambler 400, I just lean back, get a good hold and nail it.
Old Sep 21, 2000 | 09:47 AM
TheQuadfather's Avatar
I have to lean forward in order NOT to pop a wheelie.
Old Sep 21, 2000 | 12:52 PM
scramdaddy400's Avatar
You got that right quadfather!
I have a POLARIS SCRAMBLER 2x4 and even though it's stock I'm still sitting on the tank most of the time.
Ive got the wheelies down pak what I do is I sit back on the seat (about where the polaris Writing is) and hit the gas and pull back.
During the wheelie all I do is keep the throttle steady and if I fell I'm dropping I blip the throttle.
When get to high I don't let off the throttle
all I do is tap the rear brake. (polaris rear brakes are'nt very good so there not going to slam you down).
RIDE THE BEST!!!!!!!!!!!
2000 Scrambler 400 2x4
SCRAMDADDY400
Old Sep 21, 2000 | 05:49 PM
nauvooguy's Avatar
I have a 99 trail Blazer.
Old Sep 21, 2000 | 05:57 PM
My buddies 'Blazer wheelies fine with an HPD pipe and clutch kit.
Old Sep 21, 2000 | 06:13 PM
nauvooguy's Avatar
What exactly is a clutch kit?
Old Sep 21, 2000 | 06:16 PM
You get new primary, and secondary clutch springs, and different flyweights. It makes the clutch engage at higher RPMs.
