New and...Knocking?
Old Mar 21, 2005 | 11:35 AM
silverbullet2005's Avatar
Default New and...Knocking?
Originally posted by: MWfromVA
Just after starting it, at idle. It seems if I run it a little bit it goes away. It almost sounds like there's not enough oil in the engine, however it's full...matter of fact it appeared to be too full.
the 600/700's take 2 qts of oil with a filter change but that seems to be a bit to much. I always use the two full qts. but guys have talked about using just under 2 qts so the oil level isn't over the oil dipstick full level. you are supposed to change the oil not long after breakin so I would recommend putting a few miles on it then dumping the oil and change the filter. you may get some metal particles when changing the oil, this is just part of the break in.
