oil change
Old Mar 28, 2005 | 04:47 PM
ANTIQUE's Avatar
Default oil change
what is the procedure for changing oil
on an 03 700
Old Mar 28, 2005 | 05:04 PM
xcrider's Avatar
Default oil change
Here is the Owners Manual that will give you everything you need to know.
Old Mar 29, 2005 | 08:37 PM
silverbullet2005's Avatar
Default oil change
If you don't want to spend a bunch of cash on the polaris oil change kit. you can go to autozone/napa etc and get the Mobil 1 full synthetic 0w40 oil (takes 2 qts.) then you can give the parts store the napa/wix oil filter number and have them cross reference it to other brands. The wix numbers are 51356, 51357, 51358. I then crossed the wix filter to an STP oil filter number S6607 which autozone carries. the wix numbers 51356 and 51357 both came up with the S6607 number and the 51358 came up with a completely different number. I also looked at both the napa website and the wix website. the only difference I seen in all the filters was the Micron flow number which was 8 on the fillters ending in 7 and 8. the filters ending with a 6 has a Micron flow number of 8-11 which lets more oil flow through the filter. this in return helps cool the oil and doesn't let to much pressure build up in your filter.
STP filter # S6607
wix filter # 51356, 51357, 51358.
Old Mar 30, 2005 | 12:02 AM
Treacherous's Avatar
Default oil change
Make sure you have the right allen wrench to unscrew the oil drain plug.
I believe it is a 6mm Allen Wrench.
Old Mar 30, 2005 | 08:51 PM
Default oil change
Out of curiousity what kind/brand oil filter does everyone use and what is the part number? what kind of oil? and on what size atv?
currently mine is as follows: STP filter (S6607), Mobil 1 0w40, 700EFI
Old Mar 30, 2005 | 09:08 PM
Default oil change
I use Amsoil 0W40 and filter SMF103.
Old Mar 31, 2005 | 10:42 AM
sdbowhunter's Avatar
Default oil change
Amsoil 0W-40 and Amsoil Filter SMF103.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
