hubs sticking on 99 sp
Old Oct 1, 2000 | 11:40 PM
SP5004X4's Avatar
>>i think it is alittle faster now for some reason,would hit 60mph no problem. [blue]im on stock tires[/blue].
99 sp500,warn 2500 winch,K&N air filter,[blue]26inch vampire tires[/blue] <<
"Stock" tires are 25 inch, so if your speedo said 60mph you were probably going even faster than that. Maybe I need to try that synthetic fluid in my hubs
Old Oct 2, 2000 | 03:03 PM
silverado's Avatar
yep i would try it,i have 2 sets of tires and rims,one for fast runnin during the summerand one for the mud bogs during deer season.
Old Oct 2, 2000 | 03:47 PM
walexa's Avatar
silverado,
Glad to hear it cleared up your problem. I've always run Mobil 1 in my hubs with no problems at all. Mobil 1 synthetic atf will last longer than regular atf, and will lubricate the bearings and hubs better for longer life. You can also run their 75W-90 synthetic gear lube in the front end and the transmission. I noticed you changed the fluid in the shifter. I did that as well by siphoning(sp??) the old out and replacing with Mobil 1 atf. Later,
Waylan
Old Oct 2, 2000 | 06:23 PM
silverado's Avatar
yea the shifter feels alot smoother now after replaceing the fluid in the shifterbox.
Old Oct 2, 2000 | 09:11 PM
  #15
silverado's Avatar
but do think it is alittle faster with less drag on the wheels!!! lol
blueandy88
Sep 7, 2020 03:11 PM
jdunne01
Oct 4, 2015 10:29 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
snowolson
Aug 31, 2015 03:51 PM
blueandy88
Aug 30, 2015 08:26 PM
