Sportsman headlight mod
Old Apr 11, 2005 | 10:52 PM
800EFI's Avatar
Default Sportsman headlight mod
Does anyone have a part # for the relay? I was at NAPA today, and they were having a hard time coming up with something without a #.
Old Apr 12, 2005 | 10:18 AM
20045SP500HO's Avatar
Pep Boys and Autozone have them in the lighting or radio section.
Old Apr 12, 2005 | 10:30 AM
KINGSCLEAR's Avatar
I have no idea what happened on the weekend guys but I blew all three headlights in about 2 mins. I spoke to a polaris tech and he asked if I had made a headlight mod. Mine was done with the diode. I'm not sure if where I tapped into the wiring if I got a bad connection and it shorted or what.I have sinced unhooked the mod and covered all wires and the lights are back to normal?
Old Apr 12, 2005 | 10:47 AM
xcrider's Avatar
You can see them on ebay by doing a search of 12 volt automotive relay. They are used in switching fog lamps etc. Here is a post on ebay
Old May 12, 2005 | 04:31 AM
  #15
TheGrandPoohBah's Avatar
I saw a new twist on the headlight modification on Montana Jack's
It gives you the choice of three different configurations; low beam, high beam or all three. Does anyone have a diagram and material list for this option?
Old May 12, 2005 | 10:28 AM
  #16
xcrider's Avatar
Ya all you have to do is put in a switch in the wire/lead from the high beam light (yellow wire). When the switch is on, low light on low beam and all three on high, switch off it is a stock set up with low and high only.
Old May 12, 2005 | 12:35 PM
  #17
I have read that you can burn up the expensive factory high beam switch, because it's not designed to power all three lights. Isn't there a way of having the low, high, all 3 configuration by using relays, to prevent overloading the switch? Elkbow makes a kit here on the forum but I haven't figured out if he uses relays or not.
Old May 12, 2005 | 12:42 PM
  #18
xcrider's Avatar
Look at my pictures. I have the wiring diagram for using a relay right there. Just print it off.
Old May 13, 2005 | 11:03 AM
  #19
Thanks for the diagram....I'm assuming you put a fuse in the 12 v wire. If I added a switch to the ground wire I could get Low beam, high beam and all three as oposed to just low beam and all three.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 8, 2007 | 02:16 AM
  #20
Guest
Guest
Posts: n/a
This kit sold on ebay works on the 800 EFi, It fits all Polaris sportsman's and takes 5 minutes to install, no cutting of factory wires. Item cost $5.99 And worked great on my atv. Mine has been on mine for 3 years with no problems
http://stores.ebay.com/Mountai...subZ245007018QQfrsrcZ1
