Belt Question
#21
Originally posted by: GeorgiaBII
Common reason for breaking the ramp buttons is jumping with the throttle on during landing. To save the buttons from damage it's suggested that once your airborn you let off the throttle until after you land. That greatly reduces the stress on the clutch AND tranny.
Thanks, Bob
#23
They are located inside the secondary. Pull the secondary off, remove the snap retainer ring and the Helix will come right out of the housing. The buttons are inside the housing and easily accessed once the Helix is removed. Each of the three buttons is held in place with a Torx head screw......just unscrew them and screw the new ones in. Put your secondary spring back in (you can choose which settings.....two on the Helix and three on the housing......I set mine at 2/2), fit the Helix back in, push it down and install the snap retainer ring. You will need snap ring pliers. Then re-install the entire secondary back on the transmission shaft using the single long bolt. The toughest part is the snap ring.
Good Luck, Bob
Good Luck, Bob
Logan Collins
Sep 5, 2015 08:03 PM
