oh crap, scrambler sprocket? I need new primary clutch buttons.
Old Jun 14, 2005 | 11:04 AM
conig's Avatar
Default oh crap, scrambler sprocket? I need new primary clutch buttons.
thanks man I used the trailer ball method and got it off. I couldn;t find a 3/4-16 bolt anywere in my town. Trailer ***** also rarly have a way to tighten them down anymore I don;t know why. The ball I found with a nut type surface to tighten from required a 2inch wrench. I don;t see alot of people having a wrench this size on hand and they can get pretty expensive.
What do you do to keep the motor from spinning? I used a engine stop from rockymountainatv.com but had to modify it to work.
CED Thanks for your help, I thank everyone else as well. just wanted to post this for informational purposes incase someone searchs.
Old Jun 14, 2005 | 11:07 AM
CED's Avatar
CED
Impact is the way to go,if you jam something in the primary you might back off the back part of the spider,which is torqued to 140 ft/lbs.Glad you were able to get it off.
Old Jun 14, 2005 | 11:24 AM
duneaholic's Avatar
Hey conig. A electric impact works really well. Busts mine off no problem. Man I could never make that ball hitch work for me.[img]i/expressions/face-icon-small-blush.gif[/img]
Old Jun 14, 2005 | 01:36 PM
mudmaster250's Avatar
Originally posted by: oghma
For the removal of the primary clutch if you already have a clutch puller then just use an air ratchet if you have one or know where one is you shouldnt have a problem with it not coming off.
when takin my clutch off my air ratchets never been strong enough to pop it off. ive always had to used to impact. i got my clutch puller from the dealer for like 25-30 bucks. i use it every time i work in my clutch. much easier to work with it on the bench, the impact pops it off in seconds.
how do u get the spider off?
Old Jun 14, 2005 | 02:14 PM
  #15
conig's Avatar
the spider needs a special tool I beleive.
I took my primary off to take it in a bag to the dealer to replace the buttons. The hope is that I will save in some labor costs, plus they usually hook me up.
Old Jun 14, 2005 | 04:19 PM
  #16
conig's Avatar
oh by the way how do I get it back on just tap it down and put the main bolt through the center of the clutch cover.
Old Jun 14, 2005 | 05:14 PM
  #17
CED's Avatar
CED
No need to tap it,just slide it on and tighten the bolt.Do not grease the shaft either.I dont have the torque for the bolt in front of me.
Old Jun 14, 2005 | 05:30 PM
  #18
duneaholic's Avatar
I believe it's 40 ft/lbs.
Old Jun 14, 2005 | 06:39 PM
  #19
yup its 40, i generally just tourqe the little ones on the bench, to 13 i believe and i just tighten the big one up with the impact nice and tight.
Old Jun 14, 2005 | 10:04 PM
  #20
Backinthesaddleagain's Avatar
Hi Guys,
What's the proceedure for replacing the primary clutch buttons? I just did the ones in the secondary and it was easy. I'm going to be installing a Heelclicker soon and was thinking I might just replace the primary clutch buttons while I'm in there if it's not a big deal.
Thanks, Bob
