scrambler carburetor
Old Jun 14, 2005 | 12:46 AM
maddmudder13's Avatar
Default scrambler carburetor
does any of you guys know where i can get a polaris 400 scrambler carburetor at? i need one for my 2004 250 trailblazer that i need for some mods im doing to it. any help would be greatly appriciated!
Old Jun 14, 2005 | 12:52 AM
EdgeRacing's Avatar
www.hpd-inc.com, ronnies.com or try ebay... you'd probably get one cheaper off of ebay. unless you want to spend $300 on a brand new one.
Old Jun 14, 2005 | 02:32 AM
mudmaster250's Avatar
theres a brand new one goin on ebay with a starting bid of 10 bucks. go for it!!!
Old Jun 14, 2005 | 09:29 AM
i just tryed ebay and lost an auction for over 110 bucks. so i thought maybe somebody on here has one or somthing. the guy at az bad boyz says to get a stock 400 carburetor and it will bolt rite up. so im not sure if the one jimmy posted will work or not? what setup are running mudmaster?
Old Jun 14, 2005 | 01:43 PM
the one that ken has is the same size outside just a bigger bore. itll to much for your motor if u dont ahve many mods though. dont pay over 40-50 bucks for one. 110 is way to much. you can buy brand new ones from dennis for about 130 bucks if u wanna go that route. brand new scrambler carb check that carb out. its brand new. its pretty nice. what mods do u have already? if u have a pipe and porting or reed mod then kens carb will work but i would try ebay first. it will work better since kens carb is bored.
Old Jun 14, 2005 | 01:54 PM
tbsleeper's Avatar
now wat kinda mods are you doing? i wouldnt run a 34 on just a pipe but if u have alot done u might be able to get away wit kens
Old Jun 14, 2005 | 02:30 PM
well i have my quad all tore aprt to send the cyclinder to az bad boyz for them to port it and stuff its, the 250 power mod kit. ive also got a hpd pipe and clutch kit on it. i called az bad boyz and he suggested to just get a stock 400 carb and it will bolt right up with no jetting changes. he highly suggested that caseu its real hard to get the jetting on the 25o carb. what do you guys think?
Old Jun 14, 2005 | 03:17 PM
well thats the reed mod kit. you could run kens but you would still be better off bidding on the brand new one on ebay or u could get a brand new one from dennis and he could set it up for u.
Old Jun 14, 2005 | 06:54 PM
alright so it looks like that kens wouldent work good? caseu it sounds like a good deal and stuff and it includes lots of jets which i like and an airfilter. but mudmaster, what setup are you running? carb,jets,clutching,gearing,and whatever else. o and who is dennis? thanks jeff
Old Jun 14, 2005 | 11:34 PM
dennis is azbadboyz. im currently the high bidder on a 34mm flatslide carb right now. i have a pipe, porting and clutching. kens carb would work fine on yours, it jsut might be a little big. i mean if u wanna get it then go for it. itll be fine. might even be better than a regular one. ive just never seen anyone running one on a 250. it might now have as good of low end responce but it should have a little better top end and midrange.
