Race gas in a stock Predator
Old Aug 19, 2005 | 01:00 PM
blackbird's Avatar
Default Race gas in a stock Predator
Originally posted by: MnFriesen
DONT PUT RACE GAS IN A STOCK PRED!!!!
higher octane fuel should not be used in a stock pred...the fuel WILL NOT burn completly like 89 will...and it will actually make you lose power...not sure about the whole reason why, but if you do a search you will found out more info
yep waste of money on a stock motor.
Old Aug 19, 2005 | 01:50 PM
Hoopie's Avatar
waste of money! it wont burn completely. You will need a higher compression than 10.5 to 1 on a 4 stroke for that. I have a 12 to 1 compresion on my motorcyle and it only requires 93 octane.
Old Aug 19, 2005 | 02:01 PM
TehWarriorGuy's Avatar
With gas prices these days, i just dont think its worth it unless ur racing
Old Aug 19, 2005 | 04:18 PM
bassetboy55's Avatar
The higher octane will actually do more damage than anything because it being soo high octane it wont burn it all and will leave residue and grime inside your engine making for a power loss down the road and a hefty clean up job if uou ever plan on rebuilding or getting inside that baby.
i wouldnt even run the 92 stuff, id stick with 87 or 89.
Old Aug 19, 2005 | 04:30 PM
  #15
ThrashAndCrash's Avatar
nevermind.....dont want to get into it...........
Old Aug 19, 2005 | 06:08 PM
  #16
theCATman's Avatar
A real compression ratio of 10.5:1 may benefit from high octane, however.... I'd darn near put money on it that the true comp. ratio is more like 9-9.5:1 The 10.5 is a static compression ratio & Polaris uses it as a marketing tool so everone can brag how "my quad has 10.5:1 compression stock" Heck, the Z400 & its clones have an advertised ratio of 11 or 11.5:1 and don't need race fuel, because the real ratio is more like 10:1 or 10.5:1 and that 11.5 is the static ratio. So, why would the Predator need anything over 90 octane?? It wouldn't.
Old Aug 19, 2005 | 07:38 PM
  #17
polarisbob's Avatar
Originally posted by: 700atWASHINGTON
PolarisBob, I believe highlifter dicontinued the tach and temp guage, I haven't been able to find it on their website.
ok thanks
Bob
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
Sep 1, 2015 01:45 AM
