350 or 400? sane different??
Old Oct 5, 2005 | 06:47 PM
SCRAMIN's Avatar
Default 350 or 400? sane different??
are the lower cases the same on a 350 and 400? local shop has set of cases for 350 brand new for great great price not sure if will work on 400 do know crank is the same and cylinder should bolt down correct?? is it that the bore is different please help want to have back togther buy end of month
Old Oct 5, 2005 | 07:52 PM
RickRitter's Avatar
They won't fit . Base gasket is different .
350 and 400 cranks WILL swap .
Counter balancers WILL swap .
Rick
Old Oct 5, 2005 | 08:21 PM
SCRAMIN's Avatar
is the actual base different size or dose the hole where the rod is need to be bigger for piston clerance? is the 400 cylinder bigger diameter than the 350
Old Oct 5, 2005 | 08:24 PM
Bradracer18's Avatar
yes.......that is why it is a 400......not a 350........
Old Oct 6, 2005 | 12:40 AM
RickRitter's Avatar
The bolts are in the wrong place , the ports are different (old lawsuit forced change) , it is just not going to work .
Rick
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
Dman28
Apr 4, 2013 08:07 PM
Dhunter830
Oct 14, 2012 11:25 AM
scrambler400enoge
OHV Riders Rights and also Politics
Jan 17, 2012 04:08 AM
quadnut
Jun 12, 2001 04:41 PM
