Oil Pump Gear?
Old Oct 13, 2005 | 12:19 AM
cmatthews24's Avatar
Default Oil Pump Gear?
How do I remove the oil pump gear off the crank of a 96 xplorer 300. I'm trying to rebuild the motor but having trouble with gear because it's holding a bearing on the crank.
Old Oct 13, 2005 | 01:39 AM
Polaris500HO4x4's Avatar
i havent seen one of these before but i would say there is either a key or some kind of snap ring holding it into plave
Old Oct 13, 2005 | 01:41 AM
Here is the set up Crank shaft
Old Oct 13, 2005 | 12:20 PM
RickRitter's Avatar
It takes a hydraulic press and a bearing seperator/ gear puller . They are pressed on at a pretty tight fit . I ussually take the bearing and gear at the same time , this keeps me from chipping gear teeth . The bearing is heading for the trash can anyway so I don't worry about stressing it to much .
Don't try any "hammer chisel " methods , you will regrett it .
Rick Ritter
ghost civic
Jan 15, 2020 07:43 AM
SDR-II
Sep 29, 2015 01:06 AM
house1
Aug 9, 2015 10:49 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Mikea1978
Jul 4, 2015 12:37 PM
