Changing Scrambler Hubs
Old Oct 13, 2005 | 02:31 AM
nighthawk2's Avatar
Default Changing Scrambler Hubs
I was wondering if there was anyone that has changed their rear scrambler hubs to the rear predator hubs ? I wanted to change my 2001 polaris 500 scrambler 4x4 rear hubs to the polaris predator hubs if they will work with my stock axle. I want to be able to put on the ITP Baja wheels on my scrambler but they don't make them for my bolt pattern on the rear but they do for the polaris predator. If this will work leave me know what I will need to get or do to make this work. I might be interested if someone has the right parts I need at the right price as well. thanks for all the replies.
Old Oct 13, 2005 | 01:00 PM
XtremeSkier's Avatar
PM speedwerx in his forum and he should be able to let u know
Old Oct 13, 2005 | 01:13 PM
jhama78's Avatar
Whatever info you find out please put it back here in this thread... Im interested in this swap as well for my 01 scrambler.....
-j-rOd
Old Oct 13, 2005 | 04:53 PM
conig's Avatar
its expensive, but I think you can do this if you run a firestick axle. I know there are hubs to change over to a 4/110 bolt pattern. I just can;t remeber were I saw them at.
Old Oct 13, 2005 | 08:38 PM
powerslider's Avatar
The hubs will interchange, I swapped them on my quads. The axle spline is the same....
Old Oct 13, 2005 | 09:18 PM
nighthawk2's Avatar
powerslider you said that you did this and the hubs will slide right on my axle splines with no problems. what year predator did you get the hubs off ? I was told that there is a difference between the 2003 and 2004 predator hubs and I'm not for sure what the difference is or which ones I should use.
Old Oct 13, 2005 | 09:36 PM
All the hubs will fit the axle, the difference is the bolt pattern. The 03 had a 4x156 bolt pattern and the 04 up use the 4x110 which is the same as Honda's and much easier to get rims for, get the 4x110 if you can. Check around the forums, you may be able to find used ones as new ones are 70+ dollars each......
Old Oct 14, 2005 | 12:55 AM
i wish i could get some baja rim's to!
that's cool that u can switch the hubs
maybe i'll do that some day, i want to paint my yellow tho, that'd be sweet
Old Oct 14, 2005 | 04:24 PM
SCRAMIN's Avatar
also if you switch the hubs to the old pred hubs you can use sportsman wheels and tires makes interchaning easy if you own sportsman and scrambler
Old Oct 14, 2005 | 06:05 PM
duneaholic's Avatar
Great info Powerslider. Thanks.[img]i/expressions/face-icon-small-smile.gif[/img]
