Carb Idle Question.....
Old Oct 13, 2005 | 03:01 PM
94sport400L's Avatar
Default Carb Idle Question.....
I have a 94 sport 400L. In order for it to idle at all, the idle screw has to be turned in all of the way. Any suggestions on what may be the problem?
Old Oct 13, 2005 | 03:23 PM
conig's Avatar
weres your air screw? sounds like it could be getting to much fuel or is way out of adjustment by the handle bars.
Old Oct 13, 2005 | 03:41 PM
The air screw on the carb is turned out 1.5 turns - (according to my manual)
What do you mean out of adjustment by the handle bars?
Old Oct 13, 2005 | 04:23 PM
Bradracer18's Avatar
Sounds like your idle jet is clogged......
Old Oct 13, 2005 | 04:49 PM
conig's Avatar
well its been a while since I had the stock throttle cable, but I beleive there is an adjuster on it so you could tighten it up some I loosened mine as I had the opposite issue as you.
I'm inclined to agree with brad I didn;t even think about the air jet. good luck, hope you get it figured out.
Old Oct 13, 2005 | 05:28 PM
Thanks for the info guys...
I'll take a look at the jets and the throttle cable.
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
