headlight pod
Old Oct 14, 2005 | 12:23 PM
chamm's Avatar
Default headlight pod
hello....I am new to the forum. I have a question..just bought a used Sportsman 335...the highbeam headlight in the pod is burnt out...it did not come with a manuel...took a quick look at it but could not get the pod open (off)...any suggestions would help...also.. I have noticed that several of you have added the mod kit to the headlight system...did this make a big difference when riding at night? I am a duck hunter and the extra light would be nice when setting out bocks!! thanks.
Old Oct 14, 2005 | 12:50 PM
XShowtimeX's Avatar
Go to Polarisindustries.com on the home page is a link to owner manuals and part manuals, just need to get a login ID and password, pretty simple.
Old Oct 14, 2005 | 01:39 PM
chamm's Avatar
Thanks...I was on that site and they only have the owners manuel supplement...not the whole owners manuels....I will go and take another look though....
Old Oct 14, 2005 | 02:33 PM
XShowtimeX's Avatar
I'll take a look to and let you know
Old Oct 14, 2005 | 02:51 PM
XShowtimeX's Avatar
What year is it?
Old Oct 14, 2005 | 02:58 PM
chamm's Avatar
it is a 1999
Old Oct 14, 2005 | 04:00 PM
XShowtimeX's Avatar
Choose the parts manuel not the owners. I see that they only have the owners manuel supplement under owners. The parts manuel has some nice diagrams, should give you a good idea how to get it off.
Old Oct 14, 2005 | 04:04 PM
chamm's Avatar
thanks for the info....I will take a look at it..
Old Oct 14, 2005 | 06:50 PM
BikKat's Avatar
Front two corners have philips screws holing it on, your best bet is to remove the rack and the front plactic hood, or use a very short screw driver. Then there is only one screw on the back.
SLG
Old Oct 17, 2005 | 10:32 AM
chamm's Avatar
thanks...I removed the rack and had better access to the screws...the only problem is the bulb was perfectly fine...I heard that polaris was prone to a relay going bad...Any insight??
Whitelx1
Oct 2, 2015 10:55 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
PrairieDog126
Sep 16, 2015 01:33 PM
