05 Predator Second Gear??? *Glamis inside*
Old Oct 19, 2005 | 05:31 PM
predtldrider's Avatar
Default 05 Predator Second Gear??? *Glamis inside*
Also, if you have the standard pred the gearing is different than in the 05 TLD, so comparing the two gear to gear is pointless. I had an 04 with the regular gear box and I usually had to downshift to make any real big hills. You want to get a good run at the hill in the highest gear you can, then just start grabbing gears to keep your revs up, once you lose momentum in the sand your done......
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
