03 SP 700 Brake problem
Old Oct 17, 2005 | 10:49 PM
upnort's Avatar
Default 03 SP 700 Brake problem
Riding this w/e pulled brake lever and went all way to handle bar. Was going slow so did not hit anything. Found master cylinder empty also found lots fluid inside right rear rim. Got home & cleaned up tonight and found 1 brake pad MISSING. This caused caliper piston to press on rotor which did not agree with the piston so busted the seal in it. Take to dealer tomorrow see how bad actually is.
Old Oct 19, 2005 | 12:28 AM
TJ700's Avatar
same problem here.
i plugged the rear hand brake line and removed the caliper.
i can spin the rear tires forever now.
reminds me of driving my car.
it was a 10mm bubble flare if i remember correctly.
seal kits.... are outrageous.
60 bucks was the cheapest i found for a new piston and seal.
good luck.
toonces
Oct 16, 2019 12:11 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Chuck188
Jul 17, 2015 02:45 PM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
