425 Magnum problems/ cutout HELP!
Old Oct 19, 2005 | 01:05 PM
Mavpolaris's Avatar
Default 425 Magnum problems/ cutout HELP!
I have a 98' 4x4 425 Magnum that just started messing-up. About a little more than half throttle it cuts -out ,poping thru the carb and just bogs down.If you back off,it will idle smooth and if you rev it up slow,it's fine tell you get about 3/4 throttle. Checked fuel,valves,carb,ETC,with no luck, Could it be the limiter????? anyway to adjust?....
Thanks for any help.........MavP
Old Oct 19, 2005 | 02:19 PM
cornbread2's Avatar
Unhook the rev limiter and see how it runs.
Old Oct 19, 2005 | 03:22 PM
Mavpolaris's Avatar
Disconnected the gray/orange wire,no change.....................
Mavp
Old Oct 19, 2005 | 03:33 PM
Rhinos57chevy's Avatar
I had an EX400 that did the same thing. If I ran at part throttle for 20-30 seconds and tried to accelerate it would die and fall onits nose. If I backed off just a little it would be ok. I found that dirt in the tank and a dirty fuel filter was causing the fuel bowl to empty out an it could not recover fast enough. Hey its a cheap thing to look into.
Old Oct 19, 2005 | 06:23 PM
Mavpolaris's Avatar
Tryed that ,the only thing that helped was cleaning the carb out................but still has problem.
Old Nov 13, 2005 | 10:08 PM
PNB's Avatar
PNB
MavP,
Did you ever find the problem with your 425 Magnum? I have the same exact 4 wheeler and similar problems you have been having.
Mine idles fine but spits and sputters when you open the throttle. Thanks, PNB
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
Dan Newberry
Aug 30, 2015 09:42 AM
