FUEL PUMP SCRAMBLER?
Old Oct 20, 2005 | 05:12 PM
SCRAMIN's Avatar
Default FUEL PUMP SCRAMBLER?
do you need a fuel pump i am putting in a pro x 440 motor that has fuel pump do you need it because atv gravity fed please help thanks
Old Oct 20, 2005 | 06:22 PM
conig's Avatar
do you mean a 440 piston or a 440 snow mobile engine? piaston no, snowmobile engine most likly yes because of carb design.
Old Oct 20, 2005 | 06:26 PM
SCRAMIN's Avatar
yes 440 snowobile the carbs are tmx 34 mikuni flatslides we run a set on a banshee with no problem will this need the fuel requirments thanks
Old Oct 20, 2005 | 06:31 PM
conig's Avatar
I don;t know enough about the motor so I hope someone elsewill chime in. I usually don;t mess around when it comes to fuel if its there in a snowmobile I personally would want it in a quad. just me.
Old Oct 22, 2005 | 11:24 AM
baxy's Avatar
well I doubt that the tiny petcock can supply enough fuel by gravity for a high rpm motor like that
consider that the stock application (snowmobile) runs a larger fuel line with a pump
it is likely you will also need to use the pump
the donor sled will have all the hoses and such already there to make the pump work anyways
mtdewmn
Jan 19, 2017 12:13 PM
house1
Aug 9, 2015 10:49 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Mikea1978
Jul 4, 2015 12:37 PM
