polaris sportsman 500 Motor boggs bad when i give it gas
Old Oct 29, 2005 | 12:01 PM
  #31
powerslider's Avatar
Default polaris sportsman 500 Motor boggs bad when i give it gas
Broke the flywheel with a prybar? imagine that. Bet he broke more than just the flywheel. You've tried eliminating the ETC? Hook a test light to ground and the neg side of the igniton coil if you can, the light should flicker/flash (running) regardless of throttle opening, if it stops then you have electrical issues...
Old Oct 30, 2005 | 11:33 AM
  #32
sgajan's Avatar
powerslider:...yeh the throttle control is working..ok i will try to hook a test light to it...im just not sure what the negative side is of the coil.?..
Old Oct 30, 2005 | 11:56 AM
  #33
Try it on the small white wire with a blue tracer at the coil, make sure the coil is grounded good to the frame....
Old Oct 31, 2005 | 08:57 AM
  #34
sgajan's Avatar
Powerslider..ok..you said it should steady repetitive flash at any throttle? I will try and see. Thanks
Rungunner...any luck???
Old Oct 31, 2005 | 09:37 AM
  #35
Rickvit's Avatar
Might sound dumb but I had the same problem with a Honda Foreman a couple of years ago I brought the bike everywhere no one could figuer it out,Iwas talking to guy at Sears(of all places)he repairs lawnmowers he tells me just drain all the gas and put new gas.Ileave there thinking what a moron,so I go home and figure why not nothing to lose,guess what?machine ran like new!give it a try you got nothing to lose.
Old Oct 31, 2005 | 10:51 AM
  #36
sgajan's Avatar
ok i will try it.... thanks
Old Oct 31, 2005 | 04:48 PM
  #37
Kerbbirds's Avatar
had one do something simular, the guy never shut the gas off when not in use and the needle and seat went bad. filledthe cankcase with gas. Makes them really rich, check this out.
Old Oct 31, 2005 | 04:54 PM
  #38
stumpjumperII's Avatar
Have you checked the timing and adjusted your valves , it seems like you have elimiated all the rest
Old Oct 31, 2005 | 07:39 PM
  #39
sgajan's Avatar
kerbbirds,,,,ive never checked to see if it has a drain on the crank case..it has oil injection i know but i dont remember seeing a drain for the crankcase...anyone know if it does have one on the bottom b4 i go to check on this? stumpjumper,,,ive checked the timing and it looks fine...chain is tight
Old Oct 31, 2005 | 08:47 PM
  #40
Originally posted by: sgajan
Powerslider..ok..you said it should steady repetitive flash at any throttle? I will try and see. ThanksRungunner...any luck???
That's right....
