predator intake?
Old Nov 22, 2005 | 03:38 AM
FMFScrambler400's Avatar
Default predator intake?
I was told that u can put a honda civic short air intake on a predaton if u remove your air box does anyone know anything about this?
Old Nov 22, 2005 | 08:09 AM
spyder6's Avatar
lol... civic intake [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Nov 22, 2005 | 09:19 AM
Bradracer18's Avatar
Yep, you sure can. It works quite well too. Basically the civiic intake gives a long tube from the carb, giving the carb the vacuum it needs. Then you can put a special K&N filter on the end of it. Only thing I don't like about it, as apposed to my clamp on.......is that mine is closer to the middle of the quad, where this setup is right above the tires....leaving it open for the environment. As said above, check out pred owners....
Old Nov 24, 2005 | 11:05 AM
curb's Avatar
i just bought a honda civic intake off of ebay for less than 30 bucks. it is better than spending 120 - 160 bucks on those other billit alum. filter kits. does the same thing.
Old Nov 25, 2005 | 12:10 AM
Webopper's Avatar
The only thing I don't like about the Civic intake is that you have to manually attach it to the frame. Most folks are doing that with with bungee or wire ties, but if those come loose and you break the intake or it comes off somehow and don't know it, you're screwed. As Brad mentioned, your filter is right there in the elements too. Not an issue for me really, but I like having some protection around it just in case.
I thought about going the Civic route, but you accomplish the same thing with a clamp-on. Fewer parts and less hassle, so that's what I'll be putting on.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Elkaholic
Sep 6, 2015 02:44 PM
