High/Park Lock out Mechanism
Old Dec 13, 2005 | 10:02 PM
Jbrd's Avatar
Default High/Park Lock out Mechanism
Hey, I have a 2005 ATP 500 HO. Today after I shifted out of high gear, I was no longer able to shift back into high or park, even when stepping on the foot brake. Would the high/park lock out mechanism be the culprit? Any other thought? What might I look for? Thanks for any hints.
Old Dec 13, 2005 | 10:06 PM
MnFriesen's Avatar
We had that problem with our 700, except we just couldnt get it into high...I think the dealer said that the problem had to do something with the transmission...
Old Dec 14, 2005 | 03:15 AM
jimmypsp700's Avatar
I heard its a spring in the shifter drum that can be removed.
FYI...
Beware of hard shifting when moisture gets in the drum and freezes.
Jim
Old Dec 14, 2005 | 07:08 AM
Jbrd's Avatar
Thanks for the replies. Could be frozen moisture, been riding in the deep snow, maybe I will try thawing the machine. So, the lockout mechanism is a spring in the shifter drum? If it is removed you no longer need the foot brake to shift? Anybody done this mod? Thanks for the help!
Old Dec 14, 2005 | 08:08 AM
floodrunner's Avatar
Actually you can override the Park/High lockout real easy. There’s a spring attached between your foot brake and the lockout mechanism. Just hook the spring to something else so there’s constant tension (the frame?) and no more lockout (assuming everything is working as it should)
At first glance not having to step on that pedal to hit High or Park would seem to be desirable. But after giving it some thought, when we’re in deep mud (or for those who plow snow) it’s nice to have a positive stop at low and reverse without having to concentrate on hitting the right gear. I don’t know, it’s a 45/55 split for me (with 55 being stock function). Maybe I’ll try riding with it disabled for a while and see how I like it.
As far as problems with shifting the first place I’d look is inside the black cover on the side of the tranny. You could have some ice in there causing the weirdness.
Old Dec 14, 2005 | 10:55 AM
99farmboy's Avatar
I was talking to my dealer the other day and on the 06 models you no longer have to step on the foot brake to shift into HI or PARK. I kind-of liked having to step on the foot brake because it was easier to "toggle" between LOW and REVERSE without having to look at the display each time. I asked why and he said people were forcing it into HI or PARK and causing problems. It wasn't the owners that were doing this but the people they loaned their machines to.
2quiker
Mar 22, 2022 08:36 PM
Customer Service #1
May 15, 2020 08:46 AM
jdunne01
Oct 4, 2015 10:29 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Sassinm1
Sep 30, 2015 04:23 AM
