800 primary clutch
Old Dec 29, 2005 | 09:40 AM
lawnboy2121's Avatar
Default 800 primary clutch
What is involved in putting a 800 primary clutch in a 05 sp700. Do ypou run the same belt or what else to you need. Is it better then a aftermarket clutch kit? does anyone know the prices?
Old Dec 29, 2005 | 01:51 PM
SPORTSMAN70003's Avatar
Its pretty much just taking off you primary and putting the 800 primary on. You can use your stock weights, spring and belt. I got mine at the dealer for $349.99.
Old Dec 29, 2005 | 06:01 PM
JjEjFjf's Avatar
Whats the differance between the 700 and 800 clutch?
I see the alot of people change them.
Old Dec 29, 2005 | 06:04 PM
conig's Avatar
800 hundred primary starts out in a lower gear good for a ute.
Old Dec 29, 2005 | 06:08 PM
Yea lower ratio = tons of low end grunt [img]i/expressions/face-icon-small-happy.gif[/img].
Old Dec 29, 2005 | 06:16 PM
JjEjFjf's Avatar
Thanks for the info.
Old Dec 29, 2005 | 06:32 PM
Does is pull harder all the way through the rpms or just off the line. My machine seems to have a flat spot around 40 or so
Old Dec 29, 2005 | 07:57 PM
Mine pull harder mainly off the line.
Old Dec 29, 2005 | 08:40 PM
jayri's Avatar
You can use the same belt...I believe the 06 700carbed uses the 700 belt with the 800 primary. Definately a big bottom end gain with the 800 clutch, mine will pull wheelies in high now and that's with 27 inch Mud-lite XTR's.
Old Dec 29, 2005 | 09:32 PM
baxy's Avatar
do you lose and top end????
