preload spring adjusting tool?
Old Dec 29, 2005 | 05:48 PM
JjEjFjf's Avatar
Default preload spring adjusting tool?
I read somewhere that the sp800's come with the tool (in the tool kit) to adjust the preload on the rear springs.
Did anyone get this tool?
I did not.
Old Dec 29, 2005 | 06:00 PM
floodrunner's Avatar
My tool for that job looks an awful lot like a BIG channel lock wrench, because it is. The little spanner wrench that comes with the machine (usually) is junk.
Old Dec 29, 2005 | 06:06 PM
JjEjFjf's Avatar
Thanks floodrunner.
I use channel locks as well. I was just wondering if i didnt get something that i was supposed to.
The lack of this tool (which by all meens is NOT that big of deal) just adds to the dissatifaction of my purchase.
Old Dec 30, 2005 | 08:25 AM
Yeah, I don’t know what’s going on with that. Six out of seven guys in our group ride ’05 SPs. Some got the wrench some didn’t. Even if you use the spanner wrench its handle is too short to get enough leverage to turn the spacer against the tension of the spring so you have to grab its handle with another wrench or slip a cheater pipe around it. Might as well just use a channel lock wrench.
Sorry to hear you’re dissatisfied with your purchase.
Old Dec 30, 2005 | 11:27 AM
cornbread2's Avatar
If I had a dollar for every one of these I have seen broken from using the wrong tool I could take off work for a while.
NEVER EVER even think about using vice grips to turn it. When you clamp the vice grips down it WILL shatter into several pieces and these things are a bitch to replace without the proper tools.
Old Dec 30, 2005 | 11:50 AM
That’s good advice cornbread, but no one here is advocating using Vise Grips, if that’s what you’re thinking. An 18” pair of Channel Lock Pliers is my tool of choice for the job and I’ve never broken one, although I can see how you could if you squeezed it hard enough.
merryman
Jan 19, 2016 04:29 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Stever6368
Aug 16, 2015 07:34 PM
dougn85
Aug 5, 2015 07:20 AM
Schneider
Jul 24, 2015 05:05 PM
