TrailBoss 330
Old Jan 11, 2006 | 08:33 PM
Tyayo420batavia's Avatar
Default TrailBoss 330
a friend of mine told me he had a 2003 trailboss 330 2wd he baught off of someone who rolled it. It didnt run when he baught it but he put a new plug in and it runs, but only has about 60psi compression, whats wrong with it and what can you do about it to repair it? I want to buy it from him for 800, is it worth it?
Old Jan 12, 2006 | 04:51 AM
bump....
Old Jan 12, 2006 | 07:45 AM
ftwflh's Avatar
Have him try to adjust the valves first.
Old Jan 12, 2006 | 08:12 AM
scootergptx's Avatar
Supersock
Hired Gun!
To what degree are we talking rolled? A light roll, much like mine took, cost me 500 dollars to fix. Check the motor mount in front and see if it is bent. That will give you an idea of how much torque was put on the frame when it rolled. That would be the next question, was the fram damaged? Then I would wonder why my friend isn't fixing it, and selling it for more, or keeping it. If it does turn out to be doa, can your friendship survive that.
Old Jan 12, 2006 | 05:18 PM
i guess it was just rolled 3 tiumes in an accident and it fires easy just low compression, and for 800 i wanna jump on it but i want to know what to do to fix it first...i think ill get it anbd sit on it if i have to...
Old Jan 13, 2006 | 02:57 AM
slidesquad's Avatar
buy it worst comes to wors u put a cupple hundred more into and have a verry good running quad
Old Jan 13, 2006 | 06:26 AM
RyanDS650x's Avatar
Sound like a simple fix, if the compression is that low put a new piston and rings is it, new plugs, and some fresh fuel. Shouldnt cost you more that two to three hundred bucks, maybe more if you have a shop do it for you.
Old Jan 13, 2006 | 07:47 AM
ftwflh's Avatar
I have one of these and when it gets hard to start,runs bad I checked the comp first time it acted up and it was low but I checked valves and the intake valve was tight.So now I just set the valve a couple times a year and it runs great.
Old Jan 13, 2006 | 08:09 AM
Supersock
Hired Gun!
Sounds like a good deal then. Of course, you could always part it out on Ebay. btw, I need the boot from the carb to engine [img]i/expressions/face-icon-small-wink.gif[/img]
68_327_c20
Nov 25, 2023 12:26 PM
Magistar
Apr 13, 2023 04:39 AM
Myronh
Sep 8, 2015 11:27 AM
binky79
Jul 30, 2015 06:37 PM
2000Polaris
Sep 13, 2000 10:22 PM
